spacers
i need to raise my front suspention on front of car as by 5 mm does anyone know where i can get some made it is standard set up but just catches my bumper on drive when i go in and out
You can buy spring asisstor blocks for towing, they are a rubber block that goes between a pair of coils, they generally raise the car up a bit.
thanks just ordered some see if they are any good if not new coilover
You'll find that most coilovers will be substantially lower than stock on the highest setting unless you mess with the preload a fair bit. If your having ride height problems on stock springs they must have sagged a fair amount so you will be better off replacing them rather than getting coilovers, you'll save money too.
