Hello guys,
I'm putting together a new pc with an AMD Athlon xp2200 processor. The only thing is, when the machine boots it recognises the processor as Athlon xp1500+ ????????????
The only options I have in the bios to change frequency/voltage are:
clock speed spectrum - disabled
cpu/mem/agps's freq - 100/200/66
cpu clock ratio - default
cpu voltage adjust - default
I think these should be changed to:
cpu/mem/agps's freq - 133/200/66 or 133/266/66
cpu clock ratio - 12.5
Any ideas - I don't want to screw anything up :(
Vijay
What motherboard do you have? You may need to update the bios.
it's a new main board - MSI MS6373 (v1.x) K7N420 PRO
So is it nothing to do with those adjustment I asked about??????
Vijay
No most Motherboards will have an automatic setup. If its not setup for automatic then do it. They manual setting nowadays are only for overclocking.
http://download.msi.com.tw/support/bos_exe/6373v27.exe
There you go. Bios update to allow AMD 2100+XP to AMD 2600+XP chips. ;)
Below is the MSI site where I found the bios update
http://www.msi.com.tw/program/support/bios/bos/spt_bos_detail.php?UID=10&NAME=MS-6373
And
Is the MSI home page. Book mark it an keep the software upto date. ;)
Stuart
cheers Stuart - once again much appreciated!!
Vijay
