help with this
I recently removed my interior from my n/a and the drivers door panel is missing the metal bracket top right hand side which screws panel to the door edge and is hidden under the plastic bit of trim does anyone know can you buy a new one and if so where as once my interior is all done be nice if it all fitted back together perfectly without any flapping bits :)
I believe it's pop riveted to the inside of the door card, it's not something you can buy separately, but I am sure you can get a shitty old tweed one for a few quid and remove it from that.
so i'm super glueing it on then lol, if its under the vinyl then i presume that would need come off another riveted on and vinyl glued back in place sounds like a task and a half lol,
Hi David...... use Araldite............. forget superglue just isn't strong enough....... I think I actually used a hot glue gun on mine......
cheers mate i wil see when comes round to it might have the chance of some uk spec doorcards seat belts so if i can i will not big fan of the belts on door since my crash :(
