protoj ·
Hi guys.
I'm on my way down from Doncaster to Sittingbourne in Kent. My car is in Sittingbourne and the fan belt has snapped.
Just wondering if anybody has a fan belt they are willing to sell me as I need to be able to get the car back to east sussex today.
Signal isn't great so if possible send a text to 07874077200.
Any help with this will be greatly appreciated.
Thankyou
Mark
