Will any Nissan Brake Master Cylinder fit a Z32?
Hey guys.
What i need to know:
Can I fit a Brake Master Cylinder (BMC) off a Skyline/S body to my car?
Why:
I need a none ABS BMC for my car, none ABS Z32s are rare and so are BMCs for them it seems
The Reason for needing to know:
Since removing my ABS and plumbing in my hydro I have really bad brake bias. I tried left foot braking last week while twinning and........... it didn't end well. I could fit an in-line bias valve. But this may be cheaper?
Only some early non turbos have no ABS. There are various BMCs are in use on the z32 through production, there isn't a set z32 BMC so with that in mind I guess it's possible, have to try I Spose. There is a mod to put your ABS on a switch so you can still have it on the road, bit late now though hey.
My NA I'd 95 (not what I'd class as early), with no abs. So they are out there.
"Coconut" is breaking an NA in Sunderland. She may still have the BMC. Worth an ask.
BM57 ABS Z32 .. only upgrade for S13/14 if using bigger calipers
BM50 None ABS Z32 .. same as on S13/14 with or without abs ...
