Flasher Unit
Does the flasher unit control the Warning Hazard lights and the indicators, or are the two separator parts from them? I have located my flasher unit which is a 3pin. My Hazard lights are working, but not the indicators. What else do I need to check?
Just buy a secound hand one.there be a few bouncing around. Thatll allmost always sort you out unless youve been pulling somthing esle about.
Is the indicator stalk easy to fit?
Also check that the hazard switch is returning fully to the off position. It's common for the hazard switch mounting to break which causes the slider switch to skew and become lodged in the mid position. The hazards will be off but the switch is not quite stowed far enough to reactivate the indicators.
Yes good point.i remember my hazard switch got stuck and affected the indicators from working.the day before i was messing with my clocks and the hazard switch wasnt home properly.a quick flick of and off.then indicators back.well remembered J P
