What size end caps for the vacuum system?
Cheers Noel, do you put proper clamps on these or will a tight zip tie do the job?
They are a very tight fitting. They are designed to withstand way more than your typical boost levels without flying off. If you must, a cable tie will suffice :)
I've seen 1.7 bar and no issues. So, IMO, cable ties not needed, but if you've got them, and are worried, they can be fitted.
