auto to manual swap wiring info
I have done the auto to manual swap have done the wiring for the reverse light. need to ground the pin on the ecu to get 15d on tick over does anyone have a pic/diagram of the pin/pins I need to ground
If you search 300zx ecu pin out on google images, you will a diagram showing what all the wires do, yo take the one for the neutral switch and connect it as a loop through the neutral switch to ground.
been looking for hours cant find clear pics of what I need to do
still confused
so you just connect pin 44 to pin 50 ?
do I cut the wire on pin44 or splice it to ground or does it not matter
thanks mark and thanks for the help over the fone you gave me really did help owe you a drink
