protoj · Tuesday at 18:48 1 day
Hey guys, i'm on the lookout for a set of 26mm front discs for my 93 N/A i think a previous owner has fitted 26mm calipers at some point as a set of 30mm are two thick, anybody know where is the best place to get a set from? Even better if you can point me in the direction of any drilled and grooved ones or something performance orientated..
Cheers in advance
