Boost leaks- is it the charcoal canister?
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
I had my intake smoke tested a couple weeks ago, and found that my LH recirc valve was leaking. Also the vacuum hose to it had a leak.
But there was a major amount of smoke coming out of the area, and I thought something else was going on. So I started testing my vacuum lines again.
I found that the short 6mm hose from the left of the balance tube would not hold vacuum. It connects to a hardline on the engine, right next to the IACV/AAC, which goes to the front of the engine, then another 6mm hose connects to a hardline under the LH throttle hose, then to one of the ports marked "purge" on the carbon canister. A 4 mm hose connected to the port underneath the LH throttle plate is connected to the second hardline under the throttle tube, and goes to the port on the canister marked "Signal Vc". Then there is a 6mm hose from a 2nd port marked "purge" on the canister connected to the intercooler pipe, and one marked "Fuel" that is obviously connected to the vent line from the fuel tank.
The 2 purge lines will not hold a vacuum. I thought they should be sealed when the engine is off. The Signal Vc port does. The service manual says the inspection procedure is to blow air into the 2 purge ports, and it should not leak, while the Signal Vc and fuel ports should allow leaks (when blowing).
So the fact that my mechanic got smoke to come from this area is technically not a bad thing, right?
But how can one pressure test a turbo system if this is going to leak air? How much leaking by the canister is normal? When there is vacuum to the Signal Vc port does that close the purge valves or open them? Open what, they appear to be open already?
I guess what I am trying to get at is- how does this canister work, and how do you tell if it is borked?
Thanks,
Mark
