Stock radiator replacement.
Hi Chaps.
For anyone that might be interested or for future Forum searches.
ย
I've just replaced my radiator as top connection has broken, really didn't want an upgraded item as I want to keep everything stock fitment and didn't want any issues with the radiator brackets not fitting or shroud issues and the like.
Anyway, a genuine item is very expensive now from the UK, even CPZ in the US are charging $440! So I took a chance with this 'Nissens' pattern part from Ebay.
It is advertised as a manual car radiator, but its actually either, obviously you just leave the auto cooler section capped if used on a manual car like mine.
Quality and fitment are 99.9% perfect, I have had no issues fitting anything, all the screw points are in the right place, as far as I can see it is 99% identical copy. It also has the bleed screw, which I know from experience not all pattern part radiators do making bleeding the system a PITA!
Cost ยฃ110 delivered.
Nissens part no.68719
http://www.ebay.co.uk/itm/320995273051?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
ย
Hope this helps someone.:)
Edited by lonezedder
  • 3 weeks later...
