Rear coilovers..
I have just installed some used coilovers on the z. I am now getting an horrendous clunking/knocking noise over bumps they also creak if I lean on the back of the car...
Are they shot? What should or could I do?
Could be, the tops are on proper arnt they? Not loose etc, did you torque them once the car was back on the floor.
Varies, sometimes an o ring sometimes a paper gasket, depends on the manufacturer. Check for play however that's what alerted me to one of my bilstiens being duff, a clunk over bumps like something was rolling about loose in the boot.
You need to check it's tight. You shouldn't have any play on that centre one, it could be as simple as the bush it sits in it's dead, or it's loose.
