autobox latest help needed
okay , noticed an odd thing , drove home from work tonight and no 3rd gear or overdrive, parked up went into shops ,came out started car and all gears had retuned , no issues at all went for a long drive all was good, parked up again , and when i returned to the car a second time it had lost 3rd and overdrive again, so i stopped , turned ignition on and off and lo and behold all was returned to full working order again ,
So the question , wtf is going on , is my box on borrowed time , is my box ecu buggered or am i missing something ?
I have noted the power light sometimes flashing 10 times when the ignition is turned on ,
any body out their able to guide as i dont want to rip it out unless i really need to .
cheers
Sayers 07929 159828
My last Zed kept doing this also. Not sure why it happened but do know that it only started after messing with my headlights.
I was told that there is some wiring behind the passenger side headlight that is linked with the autobox but can neither confirm or deny this.
The power light seems to only flash when it plays up, when you start and it doesn't flash, then you know you can pull away without issue.
