Idea for new poll...........
How about a poll to find out what the main problems people have with their Zeds.
So let's make a list first....what was the first thing to fail in your Zed.............
3 pistons/ Two rods in one go :D
Power Transistor
my petrol seems to evaporate before i do many miles in it
Need to separate stock engines from modded ones I think.
A little metal waterhose to the turbos, stock engine (at the time)
The new front discs which warped after 2 weeks
The autobox which packed up and lost all drive !
The water pump
Both the tension rod bushes
The nearside front top suspension link (twice!)
The nearside dipped beam which went south due to a dry joint on the bulb
Intermittently both main beams after the relay started failing (scary!)
All the rear lights which went through this sort of erratic phase due to a loose connector (in the internal fuse box)
And that mysterious stalling problem which turned out to be a faulty cable on the TPS
Nearside O2 sensor
Annoying propshaft vibration solved by new centre prop bearing and rear gearbox mount
High tickover problem caused by AAC/poor electrical connection
The water pump
Nearside O2 sensor
LOL is that all Andy;)
Timmy come on mate,you can beat that hands down:D:D:D
First was a headlamp bulb.
Then:
PTU
Front and rear discs warped
Tyres
Seat belt
Exhaust blowing
Water pump
Turbo
Tyres & front pads
Air con pump
Auto Gearbox
Radio
Rear speaker
Prop centre bearing
Radiator
Speed Sensor
Seat belt
Rear gearbox mounting
Engine blew up
More bloody tyres
Rear propshaft
Front discs warped
Auto gearbox - slipping again
More gearbox troubles - slipping again.
Don't think I have forgotten anything, ummm quite a long list!
