just want to check with the tec bods what my camber should be set at, i use the car for normal road use, lowered 20mm using eibach springs with kyb shocks (non adjustable) with 19" wheels, 8.5 front 9.5 rear, just had it set up but can get it readjusted if needed, it's close to the stock settings on the machine with a little extra adjustment to allow for the wider wheels, but still within the specified range.
front left -1º 24
front right -1º03
rear left -0º59
rear right -0º54
the car does feel a lot more positive on the road now than before, but don't want to wear the tyres excessively
Those look like pretty good numbers for road. I don't find a bit of camber causes too much wear, but a tiny amount of toe will wear tyres very quickly, so just make sure that's well dialled in.
front and rear toe are spot on, i just wanted to check camber settings, as i said above the car does feel a lot more positive handling wise, especially the rear where the main adjustment was done
stock settings are fine, it's when the car is lowered without putting camber back to spec that tires get eaten up quickly
