Can anyone please help by sending me some links on how to wire a rear fog light to the o/s/ light. I have a M.O.T coming up and this needs to be done I already have a wire to the back from the front fogs but all the rear lights come on when you push the fog light button any help or advise will be appreciated.
i believe there should be a separate switch for the rear fog light.... so not coming from the front fog lights.
So sounds like your fog wire is connected to the rear brake lights? Or the side lights? Either way not very good.
I would disconnect this feed from the rear lights and connect to one of the centre reversing light bulbs - the drivers side one.
Then fit a 21w red bulb and this is deemed ok.
I used a couple of bullet type male/female connectors to make the change easily reversible, so everyday but MOT day, I put the feed back to how it was and put a clear 21w bulb in for 2 reversing lights. On MOT day swap the feeds and pop the red bulb in.
One of the easier jobs.
