air con not working
right chaps my air con wont work, ive upgraded to series 2 with ecu and pod and pipes, and compressor,
had it vac/ pressurised and filled system etc 134a
compressor wont click in, fuses ok/swapped relay etc
system pressure is good tried linking pressure switch out still wont click in so pressure must be good
put direct feed to compressor hey presto works a treat and cool air
so its control side
any suggestion, faulty ecu or pod or have i missed sumat??
rich
  • Replies 34
  • Views 2.7k
Prior to changing the display to series ll what was the ambient temp ( outside ) showing, by any chance was it a very high minus figure? if so points to outside temp sensor fault behind the bumper not plugged in.
Jeff TT
Hi jeff it's plugged in but can't remember what reading was it was 2 yr ago lol
I can't remember how, but if you press a certain 2 buttons in a certain way it puts the air con pod in to diagnosis mode in which you can scroll through the sensors and it tells you what they are reading. This includes the external sensor, I used to check that one all the time when I had my series 2 Z.
Sorry I can't remember how, sure someone will know...
struggling to decifer codes on this diag mode
after hokding both buttons in i get 22
then press autp i get it counting from 1 to 49
press auto i get 20
press auto i get 50
assuming thhis is hi low setting
help ??
rich
press auto
then back to 22 again
Yeah but it didn't make sense it's supposed to say 00 on first part which mine didn't
So not sure what's wrong
any other suggestions?
anybody with series 2 aircon can you put in diagnostic mode and tell me what values it should read ??
rich
Just been out and mine read 15 with a dash under it and under that the demist symbol, pressing the fan buttons seem to go through various numbers and settings and pressing the auto button changes it all again.
I havent read the diag mode yet so dont know what it all means yet lol
Ok just read the diag mode and went out again and here are my numbers
15 press auto
49 press auto
0 press auto
50 press auto
I found pressing the fan buttons did something but i havent researched the meaning f that yet
15 press auto
49 press auto
0 press auto
50 press auto
Cheers I can't fathom why mines different
Rich, I get the same readings as groover's results above (on entry to diags - 15 with a dash under it and demist symbol). This
is without the engine started (should be running as per FSM diag instructions). I can't start the engine at the moment as I'm
servicing the car, but have you got the engine running?
Edited by AndrewG
is without the engine started (as per FSM diag instructions). I can't start the engine at the moment as I'm servicing the car, but
No bud done it without engine running
It's weird
Ps I take it with the series 2 there is no ambient temp reading
For outside
Yes no ambient temp on a series 2, i also did my check without engine running but ignition on.
All I need now I someone who can decifer using the diagnostic mode so I can work out whats stopping the air con clutch engaging
Tried it both ways
Running I get
18 1 dash demist symbol
49 2 dash fan and demist symbol
20 with 3 dashes
50 with 2 dashes spaced demist symbol
No bud but if I put live power direct up the compressor it works fine
And the system pressure is correct
I tried it with the engine on today and on the second press of the auto button i hear the click of the compressor.
Have you checked the 3 aircon fuses 2 in the footwell and 1 in the engine bay and the relay?
I've checked relay and fuse under bonnet but not inside car I'll check Tomoz and let ya know
Rich
checked footwell only 1 listed 7.5 amp
rich
