i all
Need help with this. Managed to get into the cars gearbox ecu and everything electrical is functioning correctly. However according to the main ecu my timing is 15 degrees before top dead centre. And its not picking a load signal. Is any of this related to my gearbox issue?
Sent from my GT-I9300 using Tapatalk
Your ecu in neutral at idle is 15deg and when in gear should raise to 20deg.
If its not receiving a signal then check pin 44 on the ecu which is the neutral switch feed.
Could that cause my gearbox problem? Or is this unrelated groover
If the ecu isnt receiving the signal from the box, could be the cause.
You say you checked everything electrical on the box ecu, you need to see if the main ecu sees the change in deg from the neutral switch then placed into drive.
