Indicator buzzer connection question
Some advice required please...I got myself one of these to stop driving with silent indicators on...
sounder.jpg.
I figured maybe fit on hazard connector....
or indicator stalk...
The instructions say pickup from the lights themselves, but obviously I do not want to be running metres of wire from there....
Can someone add some arrows to above pics, or is there an alternative to tell me where to pickup the L and R live, and the earth connection?
The easiest way to wire in is to the flasher unit power output supply, this is the single source trigger for each side, earth the black cable on the buzzer and connect the red to the flasher relay mentioned above, it is located in above the brake pedal.
Jeff TT
Thanks Jeff!
I'll have a look for it tomorrow, unless anyone has pics....?
Sent from my GT-N7105 using Tapatalk
Thanks guys...I remember reading your write up Phutumsch, but couldn't find it. (Only recently realised what "bump" meant lol)
It's always worth having a look through the FAQ section. We are in the process of tidying it up a bit and checking for dead links etc, however there is still a lot of useful info in there, including Phutumsch's write up :)
The ebay link I put in now doesn't work but this isn't uncommon after the passing of time, the link really needs removing and an instruction to search for 12v buzzers will probably work better.
