Hi guys i seem to have a problem with the hicas,when i turn on the engine after a few seconds i hear like a rush of fluid and air from under the car.Would there be air in the system,and how can i bleed it.Also the hicas light is on on the dash.Thanks all
Hicas light can also mean low fluid and these cars often burst power steering lines. Mine used to spurt out on full lock reversing off the drive.
Have a check of your level and look for leaks underneath. It may be that.
Abs brake motor pump does a system check a few seconds after starting, if you mean just ignition on and not actually started it could be the fuel pump priming.
Jeff TT
