misfire in cylinder 5 what to try next
Iv a misfire in cylinder 5 took the leads off the coilpacks 1 by 1
everyone dropped in revs except number 5
switched the plug from 5 to a good one no joy
switched the coilpack with a good one no joy
took the coilpack out with sparkplug and it sparked so it is getting power to coilpack
have a spare ecu tried that no joy
Any ideas what to try next injector? Or is there anything else iam missing
Any help thanks
Injector next mate, either by ear and check it ticks or test with Ohmeter
Test the plug going to the injector?
Would i be able to hear each 1 ticking over the engine or how do u mean
Engine running, place a long screwdriver over the injector so it rests on the body and put your ear to the handle.
You should hear a distintiive 'tick'.
Try the others to get an idea of the sound.....
Also, yes, check the connector itself as it will possibly be Green!
Ok il try that next
i read about the connectors gettin a build up of corosion what would be best to use to clean them
Contact cleaner is best and a small flat blade screwdriver to scrape off heavy crud......
Il try that tomorrow after work cheers for that
fingers crossed i find the fault
All injectors are ticking away so iam stumped
anybody have any ideas of where to try next
Might sound like it is ticking but it is hard to make sure as the rest of the injectors are ticking and sending the tick through the rail.
No yet ism not to sure how to do that to be honest
Have you a multimeter,if so set your multimeter to ohms(looks like a horse shoe),take of the injector plug of the injector,use the two probes on each of the injector pins you should have i think between 12 and 14 omhs for the injector to be good.
Iv a multimeter sorted for 2moro eve so il see what results i get from that
Tested the injector 12ohms on the injector
could the injector be clogged maybe
or maybe the ptu is gone bad
Ptu only transfers power to the coil packs. So if there was a spark then that's working. I don't personally rate all this screw driver jazz, too much noise and interference. Test the connector is sending out power.
Iam going to test that everything for power 2moro, ptu then coilpack injectors
noticed theres tape around the loom going to ptu and a single black wire out of it and turned back away from the ptu and back into the loom
also there was tape around the connector on the coilpack of the cylinder thats misfiring
if you have spark at the plug dont rule out the coil pack it may have spark but not enough if its gone week but if a coil pack is swapped know good and problem still persists its looking like the injector is gone the ohms may still read good but that dosent mean its not foobar
the other side of this that is a problem or could be is valve float
this can be caused by 3 things
1 your using the wrong grade of oil so need to know what you have in it
2 you have a seized lifter bucket
or
3 your valve springs gone weak which isnt uncommon and the pressure in the lifter bucket oil wise is greater than the valve spring causing it not to shut
Went at taking the plenum off 2day and when i got the balance tube off look in and there is a lot of oil in plenum
Also seems to be leaking down the back of the plenum on the side its misfiring on
Dip stick level is gone low to
is the engine f*&ked
  • 3 weeks later...
Did a compression test today and cylinder 5 is right down bout 30psi the other two on that side are low to
the other side were all fine 160psi
Would the head gasket be gone or pistons or rings?
I don't mate but if your down at 30psi on number 5 then that engine needs rebuilt..
