Uk oil cooler question
Hi guys can anyone tell me if all uk cars had a power steering cooler also is it part of the oil cooler or is it separate thanks Taff
Yes they did and it is a separate system to the oil cooler. I've deleted mine as the fins were rotten.
same as I deleted mine just 2 days ago fins all rotten
When on earth is a power steering fluid cooler ever going to be needed?? Especially considering the jdm spec didn't have them. Does anyone know Nissan's logic behind this?
Nissan added additional coolers for Euro spec cars after high speed testing on German autobahns. In the case of the PS system
the mechanical pump is designed to provide full flow at, or very close to, engine idle speed (needed for example with low engine
revs and parking). As engine revs increase and are maintained (high speed driving) more and more fluid is being pumped around
the (open spool) system. As such, the oil heats rapidly, and can without additional cooling overheat and cavitate resulting in PS
performance degredation and/or failure.
Granted that for most everyday driving the cooler is probably unnecessary, but Nissan would have been conservative for their
specifications for the European market. If you track/race your car adequate PS cooling is something to bare in mind.
Edited by AndrewG
Common problem I reckon - due to the positioning it is subject to a lot of water getting splashed over it after years of driving in the rain. I have never heard of any car suffering from PAS oil overheating (least of all a 300zx), so if yours in knackered, just disconnect the hoses and join them together; then remove the old 'cooler!! Typical Nissan over-engineering......
That's what I did to mine a few weeks ago....:wink:
Not sure if this is correct but a came across a post on sxoc stating the uk oil cooler is a nismo 19 row item.im awaiting delivery of one at the moment I'll check for any nismo branding I'm sure the small jdm cooler is calsonic brand.
  • 1 month later...
This thread contained the subject of PS coolers. Here is a post on TT.net with folks experiencing PS
failures through overheating when using their cars on the track:
http://www.twinturbo.net/nissan/300zx/forums/general/view/2576746/Power-steering-pump-issue-after-track-session.html
Edited by AndrewG
