king pin removal ?
are the king pins on the front control arm removable ? and if so how
yep they are..i wanted to replace mine but i powder coated them with all my sub frame stuff instead as mine had no play and didnt grind. so you can powder coat them with them fitted, just in case this is the reason you want to remove them.
yes that was the very reason for powder coating .when i had the rear wish bones powder coated i left the ball joints in its boiled the grease out of them. i don't want the same issue with the king pins ball races
