Coil overs and wheel fitment . Also brakes
Three things I am undertaking with the new Z . Looking good set of 18 " alloys to fit a na /zx . Do I got with the front fitment for back also . 5/114 35 ?? .. Also looking polished lip with gold bbs style inside . Been looking at affordable coilovers or is it best to sting to conventional shock spring set up ? Discs and pad s all round . Are these same fitment in the na / Tt etc . As have been asked to measure to confirm from provider ?? . My car is a 91 300zx na 3.0 v6 . Really any help would be really appreciated
Go for coilovers - Meister-R are very good (see the traders' section) and quite reasonably priced too..... TT or NA will make no difference; the coilovers are for either LWB or SWB models as they differ a lot in weight and handling capabilities!!
Plenty of good wheel packages are available on Ebay; I'm no expert on PCD and off-set - but ideally you want wider rears with a deeper dish to give the perfect stance!
Richard:cool:
im sticking drilled and grooved discs on mine soon so im taking my standard ones off. theyre in really good nick, id take £30 for them when theyre off
Same here pal drilled and grooved for going on lol cheers anyway . I was actually looking to know also for buying discs and pads was there any diff in the na and tt
Oops - just re-read my post and thought I might have misled you a bit mate.... Re coilovers, there is no difference between NA and TT; however with brakes there is.... On older cars, the front discs of the NA are a few mm thinner than those for the TT, so they are not interchangeable unless you decide to fit TT calipers. However on the later spec NA (sorry, I forget which year they changed) they used the same discs as the TT.....
Richard:clover:
I have 18" alloys with wider rears Ash. Got them from ebay two years ago and still like new (but I do clean them a lot) These are them here http://www.ebay.co.uk/itm/18-ALLOY-WHEELS-TOYOTA-SUPRA-LEXUS-SOARER-GS300-LS400-LS430-SC300-MAZDA-RX7-RX8-/301128003540?pt=UK_CarParts_Acc_Wheels_tyres_Trims_Car_Rims_ET&fits=Model%3A300+ZX&hash=item461ca0afd4 You do need 25mm spacers on the fronts to clear the calipers but they look much better with front spacers anyway.
