Hi all,i am having problems with the installation of my timing belt,i am fitting a gates timing belt all the cam notches are lining up with the belt markes but the crank mark is one belt notch out,should i turn the cams so the the notch lines up with the crank mark?Also my tensioner is seriously tight even with the 6 mm bolt that pushes back the tensioner piston i loosened the 3 bolts on the tensioner to get the belt on and still the tensioner has only 1mm of clearance instead of the 3.5-5.2 recommended clearance.Has anyone had this problem before,never seen a car so difficult to change the t-belt like the 300zx.:blink:
