Demister & Blower electrical Fault
Afternoon gents, zed flying after being laid up for years, just one slight problem I got an intermittent electrical fault with the main blower/demister, I did change the unit but no luck def an electrical fault, was going to take to auto electrician tomorrow but thought maybe you knowledgeable peps might have the answer, grateful for any advise,
Hi, push the button on the control panel the electrical light goes on but the blower doesn't work, if left on the blower sometimes kicks in but just for a few seconds and then switches off, I did have the zed serviced and asked the garage to change the blower but they said it wasn't the blower and it would have to be checked by the auto electrician, maybe is there a solenoid or something like that ? thanks for reply
The heater motor has a resister pack in the air flow duct behind the glove box this can sometimes fail and cause the motor to not work correctly, however the motor is served by two fuses in the drivers side foot well, bottom row right hand side its is essential this power supply is checked when the non working fan issue occurs because a problem here in the fusebox could also be the potential issue do note that the fuses are only live when the fan is switched on as the supply is switched by a relay on the back of the fuse box
Jeff TT
