Below is the procedure for TT.NET for changing fuel filter.They say the relay is under the drivers fotwell. This is for a left hand drive Z. Just had a look at mine and there is no sign of it on the right hand side of the car. Is it near the ECU??
Another of the simple DIY jobs on the Z. A clogged fuel filter can cause a lot of problems from simple hesitation to cratering an
1. Remove the driver's kickpanel, 2 screws are in the side of the panel, 2 are in the firewall, the last one is under the carpet by the dead pedal (5 x phillips). Remove the first two screws of the door jamb's plastic trim (2 x phillips). The kickpanel interlocks with the front edge of the door jamb trim. Disconnect the fuel pump relay (bright green in my '95) in the driver's kickpanel (1.).
It is still pn the drivers side on a RHD car. From memory you have to remove the panel into which the fuse box cover is fitted and the relay is further back towards the door jam. It's usually bright green.
