I took my zed for longer drive I hit it couple times after while i noticed problem with evaporation of the windows , like hot air stopped getting into cabin even if i incresed temperature and i noticed little water leak under passanger feets .Any idea what happend ???
  • Replies 60
  • Views 3.1k
I had a problem like that once and it was doing my head in... .
Exacly :) mine too .Ill have to look behind the radio ... if not garage ... or maybe someone from here is close to me and its good with electrics Im happy to visit and repay for help .
Jeff are you sure retirement is the way to go, I would like to keep my car going for at least another 10 years!
Me thinking the same thing.........lol
Alz.
Alz.
X2
Jeff U cnt leave Us alone
Ive already contacted two car alarm companies and none of them comeback to me , is it so hard to fix car alarm :( can anyone point me a direction
Did you check your boot. Also might be worth checking whether all your lights and things are turned off
Membership No 0780
INSURANCE GOOFA
yep ive checked the boot , I will remove centre console tomz to have a look behind radio and clock also I got someone coming next week to check that alarm .This issues are realy pain in ass :-)
Ok firstly, the radio might need a better ground, sometimes the aerial can be part of the ground loop, so check your ground for the radio when checking the inline fuse.
Do you hear the relay click when you push in the button on the door jamb for the interior lights? the relay is situated behind the panel next to the rear seat passenger side, so just next to the seat base.
Will always be here to help.
If you get really stuck and you don`t mind the drive up we can sort the little gremlins out together over a cup of tea and biscuits.
Jeff TT
Yeah I was thinking about ground as well , I will have closer look on it on Saturday :)
Cheers for advice
Jeff TT
Im tempted :)
But I want to try by myself first .
If I fail Im more than happy to visit You ;)
Kind regards
Kin regard
