low fuel levellight
Okay , even when my tank is brimmed the low fuel level warning light remains on , can anybody suggest where I need to look for the fault , or how to best trouble shoot it ,
Sayers
Float on the fuel pump I would say. It's in the fuel tank. LWB can be got at through the boot. Don't know about SWB.
that's fine mine is an LWB, next question is where do I get one and how much !!. Ill guess in advance its a dog to get at and change
Does the fuel gauge read full?
Maybe worth checking the connectors at the sender unit. Although I have not had the same problem, mine were particularly corroded.
As for a replacement unit, they vary on e bay from £15 to £40
yep the fuel gauge reads full and I normally keep the tank brimmed, thanks for your advice ill take a peek at the sender and if I need a new one hopefully mark D will be able to sort me out ,
