Pressure bleed how to
right im of to my brothers later today to see how to pressure bleed the brakes and abs unit . so as i understand it do i leave the car running. and push the pedal in two inces only then bleed nip and shut then pedal agan or do the peddal and nip at same time. cheers
Pressure bleeding you would normally screw a cap on to the reservoir, and it will have a bottle filled with brake fluid and the bottle has a line coming off that u would put say on your tyre and the pressure will blow it through so no pumping the pedal.
I have one at work that attaches to an airline u put an end on the bleed nipple and it sucks it through.
But I usually get someone to pump the pedal till it gets has hard has its going to get, then hold it down why the bleed nipple is cracked,
Keeping it down to the nipple is shut, then pump it up again.
U may have to run round the car a couple of times just to make sure its all clear.
I do abs pump, rear left, rear right, front left, then front right.
Should bleed easy if not check all bleed nipples are on the top of calipers silly mistake I made lol.
Or try clamping calipers by the rubber hoses to see if the pedal improves should narrow where the fault is if there is one.
brakes sorted now. i have some. abs unit fist then the calpers sorted. thanks for your help and advice peoples
