EGI fuse
Hello gents just a quick question. what does the EGI fuse in the engine fuse box relate to/ control? as a few weeks ago I noticed the car doesn't have a fuse in the spot marked for EGI, but car runs perfectly? Thanks in advance
Erm... PTU and therefore coil packs... Spark plugs...lol
Hi Andrew, its located in the engine compartment passenger side front of the engine bay
yea z32bolt that's the exact fusebox there with the label for egi
That EGI label/position is for a relay.
[ATTACH=CONFIG]75726[/ATTACH]
Thanks Andrew, but what system in the car does it control?
I googled it as I didn't know think it's a fuelling relay, it's related to shut down procedure. There's a fair bit on thereof you type in EGI relay 300zx
happy to help as I've been staring at wiring diagrams for the last few days. What I'm not clear on though, are you referring to the red EGI fuse, or the big Green relay as missing?
That relay provides +12v to the ECU (power sections), CAS and AFM. The EGI relay is also shown as the ECCS relay in the FSMs
I have. What year is your car?
Edited by AndrewG
hi there my car is a 1990 tt. im referring to the green relay, btw. its missing in my car and was just curious why it has no effect
It's pretty vital for it to work, however, doesn't mean the loom hasn't been 'tweaked' at some point in it's life ...
My question from the basic understanding of what it is is how does your car work without it!
I've attached the circuit diagram for '90 models. This shows the ECCS relay, together with the IGN relay. If you look, they are
practically running in parallel, both switched by the ECU pin 16, and +12v fused unswitched supplies. I did come across a post
on TT.net, which the author was also missing the EGI (aka ECCS) relay. That leaves the factory merging the two, or possibly
a previous owner did the modification. You could also check that the switched terminals of the EGI relay socket hasn't been
bridged with a small piece of wire.
efec-13.pdf
Thanks very much Andrew ill have a look and see if theres been a mod done
FYI the EGI Relay also feeds power to the AFM & CAS so either the relay is bridged or the loom has been played with
