Leak
Hi again I have a problem with a leak its coming from the passenger side just below the ecu (floor) collecting just in front on the foot well. Ive noticed its dripping by the panel which looks to hold the flare? I have removed this panel and tried various methods of fault finding also ive checked all drain holes with targa's off ive poored water down each drain hole and it all comes out at the bottom of the car, so it cant be drain holes or pipes, I have also removed the rubber section which screws into the top of the A pillar and sealed with silicone still got the problem is there anyway water can get in from behind the battery tray?
Sent from my GT-I9300 using Tapatalk
do you have you aircon on as ther drain pipe is there - make sure it exits the car :)
Hi no mine doesn't have air con
