bleeding brake ideaa to try out.
Ive had a hard time getting a firm peddle when bleedidg my bakes . now someone at work said to me after you done all four corners when you bleed the abs unit do not put your foot right down to the floor only a couple of inches 2.5 at the most then try this a few times and that should resolve the problem. thought id share that info withyou and ill be letting you know if it works.
Make sure all your bleed nipples are at the top I messed up my rears and was getting crap pedal.
Ive bled loads of zeds I find they bleed up straight away unless theres a problem.
