Depends what spec of wheel they are. You need to find the offset and widths of the ones you're looking at buying.
Here they are on a friend's Z32 for reference. I can't remember what specifications his ones were.
18'' 5x114,3 front 9,5j ET-30 rear 10,5j ET-20 i thing itis ok for me and i find on auction i my country for 800 pounds widout wheels make a photoshop on photo up
You'll need some arch work with the rears. You'll definitely need the arches rolled and quite a bit. The fronts, you'll need to remove the arch liners and you'll need to fold the lip up.
Fair enough, so you're planning on doing some work to get them to fit! Go for it! They're very rare wheels and quite sought after!
they are gonna take ALOT of work to fit, that's a very aggressive offset !!!
Is the yellow zed yours?
yes my beauty :)
i know its alot of work but is notjing to me my friend :)
I'm confused because he wants rota drift 19 inches and these weilside I like and do not know which will be better to look like
Rota Drifts suit the Z but they are cheap replicas that everybody has. i would go with the Veilside Andrews if you can work with their fitment.
If those offsets really are negative then the fronts are going to protude out an extra 55mm from the arches, and the rears are going to extend by 80mm. You will need to fit those arch extensions and cut away the original arches. Even then you may need stretched tyres and some excessive camber.
If those offsets are meant to be positive then it wont be as bad as that and you could get away without any serious arch-work.
Edited by Yowser
ok so if i decide buy this veilside how u thing maybe respray inside the wheel in white will b ok?
Dave, I don't think you could get the Andrews wheel in a negative offset. Imagine they're a '+'.
Pit, why would you want to paint the wheel arch white when the car is yellow? I'd paint them yellow to match the car. You could remove that bi-plane from the tailgate too while you're at it. ;)
car is yelow ander bonnet to so if i spray wheels yellow that will b to much u dont think so? ;) and i like my bi-plane hihihi :):):)
ok but I decided to buy rota wheels front 9.5 and rear 10.5 19 inches can anyone tell me what I have to choose et to that size? :)
what wheels this is niiiiiiiiiiiiiiice :)
They are Veilside Andrew Racing V, the ones in your first picture are Andrew Racing F ;)
Look at my sig pic that's with 18x12 et-20 with the JUN arches like yours.
