window adjustment
Hi guys, anyone know anything about adjusting the front windows so they close tighter against the targa rubber at the top? I'm sure I read you can adjust them, but can't find it.
I looked in the service manual in "bf10" there seems to be adjustment possible, but not sure if it can be adjusted in or out at the top of the window or just up and down.
Iff your door latch is missing the nylon shroud then this can cause the door to be a little slack
You can adjust the window, the easiest first is to take off the door card and there are 2 window stops, undo the bolt and slide up slightly, it will make the window sit tighter to the top of the rubber, The pin in the runner has a plastic roller bush on the end, sometimes its fubarred and causes the window to rattle when down a little, this iirc can also be adjusted.
http://www.300zx.co.uk/forums/attachment.php?attachmentid=48695&d=1244585257
Thank you groover, again ;)
znut, my latch is missing the nylon, but already adjusted the latch to compensate. And acraig like I said in previous post, look in service manual section bf (body) page 10, the diagram will show what groover means
Edited by evilanger
