Subframe & diff change
Right, got finally got The Dutchess in the garage for the winter ready for her full suspension upgrade & rebuild, subframe & diff replacement.
So...... not fazed by the suspension rebuild, however, i'm kinda dreading dropping the subframe & diff & replacing the pair of them. Was going top get Jeff to do it but as I've spent so much on upgraded parts funds are running low......
Can anyone who has changed the subframe & diif before tell me what i'm looking at time wise & the difficulties I may encounter?
Cheerz
Jamez
yep as mikey says really easy job ..
u may need a long'ish cracker bar for the Main bolts but thats about it
Rear Section of the exhaust needs to come off
Rear section of the Prop
Release the hand brake cable from the balancer
unbolt the cable from center tunnel
undo the small mount brackets 6 bolts in total
undo the bolt mount from the lower part of the shocks
4 Main sub frame bolts ..
use a Jack to lower the frame down on to the floor ..
kinda done
actually a rather easy job, 2-3 hours should easy see a subframe removed
Easy enough to do off axle stands though bud? & what else am I gonna have to remove other the exhausts & suspension arms etc.?
Jamez
Thanks for the reassurance guys :thumbup1: if I have any problems i'm coming to you :gun_bandana:lol
Jamez
yep as mikey says really easy job .. u may need a long'ish cracker bar for the Main bolts but thats about it Rear Section of the exhaust needs to come off Rear section of the Prop Release the hand brake cable from the balancer unbolt the cable from center tunnel undo the small mount brackets 6 bolts in total undo the bolt mount from the lower part of the shocks 4 Main sub frame bolts .. use a Jack to lower the frame down on to the floor .. kinda done
And the hicas lines if applicable?
Yeah sorry .. 2 unions need to be undone there on the chassis between the tank .. and subframe
Shouldn't apply though should it as ive had hicas removed & lockout bar already in place?
Jamez
redone the list
Hicas pipes between tank and frame ( if you still have it fitted )
Rear calipers fixing bolts & hang them up from the Shocks
kinda done
Jamez
yeah it wouldnt as u have all ready removed the pipe work from the main joints
Are you putting a na rear subframe and diff on ?
Thanks Mark, very helpful & with Mickey on speed dial gor back I think I'll manage it...... I hope :-)
Taff - No mate replacing my damaged TT subframe with a recond & polybushed one & a welded TT diff ;-)
Jamez
Welded diff???? You going drifting? Hope it's not a daily driver as that will be a right pain to live with lol
Lol :-D Yes mate, she was daily drive for 5 yrs, then summer toy for 2. Since the accident & now the fact she needs a full respray & am doing full suspension rebuild I fancy a change & playing on the track until ive saved enough pennies for the damage repair & respray....
Ideally dont want to weld it but dont know anyone that has shimmed a diff before, do you?
Jamez
