Any way to determine if failing master or slave clutch cylinder
- No registered users viewing this page.
The system has been bled more times than I've had hot dinners and it's still reacting like I've got air inside when warm (not even hot), the clutch almost disengages or has twice. Also when cold the pedal is right on the floor to disengage.
Yes, it's been bled normally, power bled, had a 300 pro bleed it, front of car raised and not raised etc etc, one time I alternated between top and bottom 6+ times with loads of fluid.
I can only assume one of the boosters is failing... there is no fluid leaking that I can see. Any idea how to work out which one... And yes, they were both replaced already, but about 5-6 years ago maybe longer?
If it's the slave I'm tempted to get the RPS upraded version, dunno how much that is though.
Jez.
