- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Ok so I've not seen a write up for this so I thought I'd do one to show just how easy it is, I think this is one of the most overlooked things I can make a real difference when replaced,
This will show how to do polybushes and solid bushes.
Tools needed
Drill
Heavy hammer
Screw driver
Pry bar
Blow torch
48mm socket
Ok so here you can see the original bush there's an inner and outer collar,
The arrow and circle shows the inner bush, this is the one you need to remove when replacing with poly bushes
Firstly remove the strips of rubber from each side
Ok so I don't burn the old bush out I drill them, get your drill and go round the bush top and bottom this only takes a few min
Top
Bottom
Once you've gone all the way round get a pry bar and wiggle the centre out
PLEASE DONT POST UNTIL IVE POSTED IT ALL UP
