The steering is active, so it’s uses input from the speed sensor. If the speedometer fails to work it will stop the power assist steering. You car being an import will likely have a speed converter behind the dash, loose connection here on this circuit will be the cause. You tapping probably remade the connection. Also the speed sensor on the gearbox can pop out the end, be loose, simply slowly down and speeding back up it can kick back to life.
By
Stephen ·
A14 this afternoon, Batman in a Black J reg accompanied by a G reg Grey Z, looked like part of a mini JAE convoy :)
