as above got caliper assembly & rotor off + tie rod ball joint, just got the lower ball joint & kingpin lower nut & the actual removal of the hub & steering knuckle assembly to go.....
Question is how do I separate the assembley once the king pin & the lower arm nuts are undone ? do I need spring compressors or is it a case of a long bar pushed down on lower arm & lift off???
Hope this makes sense.....
Cheerz
Jamez
once u have undone the lower bolt ... just push down on the arm with your foot and the hub will come away from it ..
Nice one, thank you Mark, knew you'd know :bow:
Jamez
