Hello,
I hope You guys understand what i mean...
So i got strange problem with my car, when i rev it really high (no matters i drive or on neutral) one (or more) of my cylinders stops working for a while. After few moments everything back to normal.
For example, i accelerating hard on 2nd gear, put 3 and no power, engine work like tractor.
The same thing is when my car standing somwere, i rev it to red line and then its start work really bad for a few moments.
No air leaks, i check 2 fuel p. regulators, i install new fuel lines, i got series 2 PTU (check 2 of them)...
Help pls?
Edited by Draxan
  • Replies 39
  • Views 2.5k
Silverline - and if i want to fix my engine so i stop this problems what i need to buy? Any links or photos pls :) .
run an engine flush throught the engine and then drain it
change filter put in the oil as discussed and run it for a day or so till all old oil is out of the lifters
then see if its cured it
do the oil first as it may fix the problem if it dosent the its new lifters as above either way you still need to change the oil
Ok in saturday i change oil to Valvoline Synpower Fully-Synthetic 5W30 and see thats helps me.
Many thx for all help Silverline :)
your welcome and make sure you put a engine flush in ;)
Hmm i think its helps :) . In saturday i was in my friend garage looking for a leaks, so i rev it to rev limit and car works fine on all cylinders :) . I make one run test today and i hope it pass it too :) .
So changing the oil to a grade as i recommended looks to have fixed it ? :)
So, test 2 - ok :) .
So yep, Your advice was correct, THANK YOU SVERY MUCH :)
This level of knowledge tells me I made the right choice when I asked silverline sort out all the ongoing problems on my car too! :thumbup1::thumbup1:
Honestly if He dont tell me to do that no way I fix it :)
Yeah mine too which has been an absoulute nightmare since the engine swap..... and also 'Grays' car, or so I believe
What can I say other than
Silverline :bow::bow::bow:
Great stuff glad its fixed it for you
:blushing:
