the front bush on the drivers side rear subframe is leaking and looks pretty gone is it possible to replace just the front 2 bushes with the subframe in the car ? i would of just left it but the car is pulling to one side so thinking this bush isnt helping things
Buy some locking collars,take an hour to fit and much cheaper.clamps up the bushes so they are redundant.you wont notice any compromise in ride.
really dont want to use collars looked in to in really want to do the job with proper bushes
If only one of the bushes is shot I can't see it causing the issue you have. If you just want to do it as a process of elimination then Jimmers solution is going to to be the cheapest and quickest method. Otherwise it's going to be a subframe out job.
Replacing the rear subframe bushes are a complete arse! I'm thinking I wish I went for locking collars now haha.
will the collars put the subframe in the correct plance its saged and leaking on one corner yes its just to see if its stops my pulling issue
Rather than a constant steering pull which you have, if the subframe bushes were bad enough to cause any issue then it would be more likely to be all over the place.
its kind of been gone for a long time and looks like its settled there .ok will give the collars ago see what happends
