August 30, 201313 yr The symptoms Only does it when engine is up to temp Appears to be near side bank as the exhaust that side spits and shakes lumpy when up to temp Very light throttle then clears up as the revs rise slightly The lighter the throttle the more violent the mis/hesitation So far; Changed the spark plugs Swapped the coil packs side to side Checked the injectors have resistance all the same as each other Checked and cleaned all plugs inc lambda, water temp, throttle position injector and coil pack What now?
August 31, 201313 yr Author By the way, I replaced my ngk r pfr6b 11c to denso k20tt I am now thinking I have been sold the wrong plugs?
The symptoms
So far;
What now?
