car still pulling left
ok i have put a few threads up about car drifting to the left been aligned its all stop on but still goes to the left all the bushings look fine there is no clunks the calipers and not rubbing wheels spin free then jacked up the guy at the garage i use say it could be a rack issue and are going to disconnet the power steering pump belt so there is no power steering and drive it and see if it still pulls. if this dont work what else is there to change
  • Replies 61
  • Views 3.5k
its stop in aglined mate all in the green done a hunter alignment machine .just spoke to the chassis alignment place just told me they cant dont anything the car is to old and its not on there system so am now very stuck on how to find out whats going on and its doing my head in big time am going to have t sell the car for some one to brake not happy as i just spent a few k on loads of new stuff for it looks like my time with the zx is coming to a end gutted
Try not to loose hope, sometimes these bl**dy Z's can be a pain in the a*s.
Just a thought, but have you measured the positions of front and back wheels with regards to the wheels being equal within the wheel arch?
IE is the gap the same when measuring from the front of the rear tyre to the inner edge of the wheel arch for instance.
Also, check that the height between the top of the wheel and the inner edge of the wheel arch, see if there is a major difference there.
(maybe poor shocks or failing springs etc') Worth mentioning that you will need to be on level ground mind.
Hi Dan, That is bad news, has the car done it since you have had it?
yes done it when i got it
yes it all seem to be the same
find a decent body shop with a jig and give them this info:
http://www.300zx.co.uk/cgi-bin/manual.cgi?list=bf&dir=&config=&refresh=&slide=42&cycle=off&scale=0&design=default&total=46
the car cant be too old. maybe too old to get settings out his book. but page 42 onwards will provide all the info needed.
been tryimg to find a jig the only one i found local said the car isnt on there system so could put it on there jig
update today i found i can get 3 fingers in between the trye and the arch in the drivers side and 4 on the leaf side also found the rear subframe drives side bush it leaking oil and is a but crushed i wounder if this is my pulling left issue
I assume the car is on level ground when you do the finger thing Dan....:wink:
yes i tryed in lever ground and even tryed it with car other way round the gap on the left hand side is diffo bigger
update have fitted new front dampers and springs and fitted rear sub frame collars to one was leaking car is stil pulling left . the car is now going to z world next week hope thay finf the issue as i really dont want to get rid of it
the car is in super clean condtion so would like to keep it am sure jeff will get it sorted for me
