Vacuum lines from plenum.....
Guys I've been wondering about something as I sometimes do. I asked my mate who knows more about cars but he could not explain this either
There are these vacuum lines coming from the balance bar to the clutch and brake pedal boosters and no doubt other places too.
But where does the vacuum actually come from?
From my understanding of physics (OK I only did A level) if I have two turbos forcing air into the plenum at 9PSI (or even 19PSI with my boost controller) or maybe even more, then surely the plenum is gonna be full of compressed air, not a lack of it (i.e. a vacuum)...... isn't it?
Does that makes sense?
Rich
You only create positive pressure or boost over a certain rpm. Roughly 3500k for a stockish car, obviously when you change gear come off boost etcs vacuum is recreated and stored there by the one way valve. Off boost the car produces roughly 7-9psi of vacuum pressure. Watch your boost gauge swing negative to positive whilst driving.
Z idles at around neg 9psi but that's all the numbers you get. Sure the pulsar is reading in psi not hmgm or what ever that jap measurement is.
