Anybody happen to know what PCD the stud holes are on ?
Also if anybody knows what the front and rear wheel offset is,or where i can find the information.
The reason I ask is that I have access to a set of 18" OZ super tourismo's from a v6 clio, as they are now partners it may be they use the same stud pattern and PCD.
Any help as ever is appreciated
Robin
From memory:
PCD = 114.6mm
Centre bore = 60mm
Offset (front) = 30mm on 8.5x18
Offset (rest) = 42mm on 9.5x18
Just watch the rear offset. You can probably go to 45-50mm on a 9.5 without problems, but a 55mm offset will catch the lower wishbone slightly on full compression. Guess it depends on the exact shape of the rim as well
john according to the link above your post pcd is 114.3, front offset is 35, rear offset as you said 42.
Without being rude john,who do you work for ?
Reason being, I used to know a guy called John Dixon who owned a 200 sx, not you is it ?
Oh well, can't be right all the time!! Just checked my wheels, the fronts are 30mm and I've never had any buffing at all.
I'm not the John Dixon you knew, I've never owned a 200SX. Went from a 205 to a 300.
