RichardS ·
Anyone able to measure the sizes of a standard side mount cooler?
Found some Vw ones this size for about £25-30 each
total l=35cm w= 14cm h= 20cm
core l= 20cm w= 11cm h= 15cm
How does this compare to std zx ones? The Vw ones are very efficient.
