power steering pot question
I've removed the hicas and the splints from my Tt pump and got myself a n.a. steering pot but the pipe that attaches the pot to the pump with jubalee clips is too big a diameter for the pot but fine on the pump side. has the pot got different size feeds from Tt to n.a. ? and/or what's the solution :cheers
also you cant really blank off the outlet as the oil passed through the channels are used for lubrication, not good for the pump.
Plus you get back pressure build up if you just block of the Hicas bit.
I followed boldys guild on removing the splints and I've had the there outlet welded up yo block it. I'll see if I can search the page again when I'm on pc later.
That's another good way :)
Boldys guide was done in may 2010 and in April 2011 was looking for a na pump Ill have to have a think...
edit cant PM him as I was gonna give him a quick nudge to see if he can have a quick look at this thread.
Edited by paulbrem
