Retro fitting start stop technology
How hard do you reckon it would be to fit this feature, the car has enough sensors to be tapped into etc, are there any DIY versions out there
I know about the key, well done for your observations so a gold star rewarded to the pair of you,
The same answer could be applied to abs , traction control etc, but my question was, how hard would it be to retro fit start stop technology (not using the key!) to a z,
Discuss............
Just fit an LPG conversion too!!!
:no::no::no::no:
Todays most random idea:lol:
At the end of the day it's just a switch that turns the starter motor, so I wouldn't have thought it would be that hard. Probably would still need to use the key to switch on the power and accs though.
EDIT: Just actually read what you want! lol. So scrap what I said..
Edited by Steams
i would assume it would have to work with in the abs sensors and your handbrake ..
sense car as stopped
hand brake applied
engine stop
then to activate it to start would have to be on throttle
press to switch engine on ... and drive away
but realistically the stop/start of any car is only a small saving of about few mpg over a tank full
is it really worth it ?
Thank you, I am not considering fitting it, but just wanted the topic covered as it hasn't been before. I'm a great believer that you shouldn't by a 300zx for fuel economy, just thought it would be a good topic to talk about
All the start stop cars I have been in restart the car when the clutch is pressed, activated by neutral selection and car at a standstill.
From what I have read s/s tech gives a saving of approx 5% (8%) in city conditions, that's quite a lot considering how much our ladies drink
