Can anybody please advise on removal of the front fog light ?
My passenger unit has filled with water and needs either cleaning or replacing but I can't see how to get it out. There's a screw on the front but this just turns and doesn't seem to do much !
Any advice very welcome.
Mark
I think you have to remove the side light and access a bolt that holds the front fog in place from behind it.
Yeh thats right. The fog light unit is held in by bolts on the back of it. So you need to remove the side lights to gain access.
Yup - basically that....
Remove the corner lights and then you need a 10mm spanner to undo the 3 retaining nuts on the back of the fog light unit. The front screws on the fog lights are (IIRC) just adjusters to move the beam pattern and not to separate the lens unit from the base. There are screws on the back of the whole unit to split the lens portion but you need to remove the whole thing (as explained) to do so....
Richard:thumbup1:
The screw on the front adjusts the light beam, if you undid it to far you might have to reasemble the spring inside
There are 3 nuts on the back of the fog to remove it
[sIGPIC][/sIGPIC]
